AdsRuss Offline
#1 Posted : Friday, 30 May 2008 4:56:50 AM(UTC)
AdsRuss
G'day all. have a red 253 sitting in the back of a ute. Does anyone know how to test if it works ok without putting it in the car? i.e can you start it on the floor or benchstart it. If so. HOW ?
#2 Posted : Friday, 30 May 2008 9:43:00 AM(UTC)
hey russ,
i am not sure, but i think you gotta get a battey, connect it too starter, when your ready, got to supply battery to coil, and then pour petrol down carby?
i think you gotta earth starter to block, and coil earth to block, but i might be total
The Yeti Offline
#3 Posted : Friday, 30 May 2008 4:40:48 PM(UTC)
The Yeti
you can fire it up pretty much as set out above, but it tells you very little apart form you know how coenct up th elctrics to start it,
even a comp test on it will be rather inconculsive
I take it you dont know the engines histoy, lets fase it if
Macquarie Towns Hot Rod Clubs new website http://www.hotrodclub.info
See The Yeti's Chev build at
http://www.ozrodders.com...rd/viewtopic.php?t=17919
adam PERTH Offline
#4 Posted : Saturday, 31 May 2008 7:45:39 AM(UTC)
adam PERTH
Adam, its the one i sold u with the HJ?
like i said, its condition was unknown to me.
However, it was well wrapped up in blankets, with rags in holes etc, which is a good sign.
goodluck.
basketcasebear Offline
#5 Posted : Saturday, 31 May 2008 8:49:14 AM(UTC)
basketcasebear
hey yeti
what the diff between comp test, and cylinder leakage test?
thanks
bcb
ptpro
some men see things as they are, and ask "why"
I dream of things that never were, and say, "bloody ripper idea mate, lets try it",!!
DOH!!!
The Yeti Offline
#6 Posted : Saturday, 31 May 2008 4:28:34 PM(UTC)
The Yeti
your standard compression test is where you put the gauge in th plug hole and crank it over reading its compression, even a very sick engine can look goof like this but its an indication, its a good idea to do both a wet and dry test just to see how much
AdsRuss Offline
#7 Posted : Saturday, 31 May 2008 8:41:42 PM(UTC)
AdsRuss
Adam,
Yeh it is that motor. I don't want to go to the trouble of putting it in and finding it's f-----d. I would prefer to rebuild it first and then put it in if it is. It's my daily driver so if it's off the road i'm screwed. Don't like walking too far
AdsRuss Offline
#8 Posted : Saturday, 31 May 2008 8:41:42 PM(UTC)
AdsRuss
Adam,
Yeh it is that motor. I dont want to go to the trouble of putting it in and finding its f-----d. I would prefer to rebuild it first and then put it in if it is. Its my daily driver so if its off the road im screwed. Dont like walking too far and it
AdsRuss Offline
#9 Posted : Saturday, 31 May 2008 8:42:59 PM(UTC)
AdsRuss
Oh and thanks for your suggestions Yeti and Bear. I will give it a go.
This page was generated in 0.082 seconds.
