#1 Posted : Tuesday, 8 June 2004 10:44:35 AM(UTC)
Just purchsed a Fairmont, great car to drive, climate control doesnt deliver any heat even when disabled, heating does not operate, can anyone help with any answers of what may be causing this problem
#2 Posted : Tuesday, 6 July 2004 4:21:28 AM(UTC)
The heater switch works on vaccum its probably got a leak or the little tube has come off the water tap. 1st check your water tap to make sure its opening and closing when you turn the heat on. If thats working you may have a blocked core, which has happe
#3 Posted : Friday, 23 July 2004 8:57:23 AM(UTC)
thanks got it fixed
