Blair Offline
#1 Posted : Monday, 2 June 2008 9:33:48 PM(UTC)
Blair
Hi I hoping someone may have some ideas on what may be wrong with my VL. Oneday it started to play up as if it was starving for fuel. When turned of it didnt want to start again. Checked fule pump and fule supply wich waz fine. Found a lack of spark and having 10 month old leads i replaced both the coil and dizy wich seemed to fix the prob untill it gets hot. We have shecked the self diagnosis codes and it comes up with thec fault codes for the air flow meter circuit, coolant temperature sensor circuit, ignition signal circuit and then after thoes it flashes the code for Satisfatory operation. Any ideas? A holen dismantler has sujested maybe the computer.
Blair Offline
#2 Posted : Monday, 2 June 2008 10:00:05 PM(UTC)
Blair
I have now just taken it for a run waiting for it to get hot and cut out and when it did ran the self diagnostics again and this time it came up with the crank angle sensor ciruit fault followed by the satisfactory operation code.
special-k Offline
#3 Posted : Monday, 2 June 2008 10:28:51 PM(UTC)
special-k
Mate I have had heaps of VL,s and you will find that its the crank angle sensor as you stated above.It is showing all the signs as two of my vehicles did when it got hot wouldnt rum properly.Change it mate and all will be fixed.
#4 Posted : Tuesday, 10 June 2008 7:54:14 PM(UTC)
Cheers. Im trying to do this on the cheap so doing this myself had a look in the manual and cant find anything on it. Could you please explain where i could find it? thanks
ED72HQ Offline
#5 Posted : Wednesday, 11 June 2008 2:14:35 AM(UTC)
ED72HQ
in the VL the crank angle sensor is in the distributor so you have already changed it - try the coolant sensor, if no luck there it will be the computer
