HZute-efi-VS5L Offline
#1 Posted : Monday, 9 June 2008 9:25:38 PM(UTC)
HZute-efi-VS5L
Just after an "Expression Of Interest" for a print run on these styled Caution/Weight Tags. (see this link:http://oldholden.com/node/61607)
what exact models did they come on?
It seems there is a few diferent styles. And we would be looking at doing them all.
They would be as per original. all made from about 0.8mm aluminium thick. Some i have seen are skinnier some are thicker. thickness range from .6mm to 1mm. So we would go with about .8 or 1mm thick. or do we need to make sure we get the thickness the same? or are you happy with .2mm thickness out here or there?
They will be as said printed on aluminium like the originals. with black????? (gloss? satain? flat?)
they will also be profile cut to shape. the holes will not be drilled. But they will be marked with a cross which will be printed in the correct position for you.
Prices expected.
if we only do the 1 $30 each
if we do about 1-10 $25 each
if we do 10-50 $22 each
+ $2 to post.
If i can get a bit of an idea for numbers and people interested?
Jason
www.stickthisdecals.com.au
#2 Posted : Monday, 9 June 2008 11:23:04 PM(UTC)
they came on ..... FX to EK... I think...
#3 Posted : Tuesday, 10 June 2008 12:35:38 AM(UTC)
HZute-efi-VS5L
no worries cheers =)
