justgm Offline
#1 Posted : Tuesday, 10 June 2008 3:02:41 AM(UTC)
justgm
Is this a real one ? e-bay #150256678867 , looks good , but eng # does not have date code ? is this right ? . Mark
monaro mark Offline
#2 Posted : Tuesday, 10 June 2008 3:25:47 AM(UTC)
monaro mark
Yeah it looks right, the 'U' on the VIN plate (skinny one) and the 'L30' on the body tag means it's a 350. The date code is under the block behind the starter motor and you need to get under it to see it. The engine plant number (11QU1) matches the body
Edited by user Tuesday, 10 June 2008 3:28:04 AM(UTC)  | Reason: Not specified
monaro mark Offline
#3 Posted : Tuesday, 10 June 2008 3:25:47 AM(UTC)
monaro mark
Yeah it looks right, the U on the VIN plate (skinny one) and the L30 on the body tag means its a 350. The date code is under the block behind the starter motor and you need to get under it to see it. The engine plant number (11QU1) matches the body tag
