#1 Posted : Friday, 13 June 2008 5:17:19 AM(UTC)
Hey guys, another quick (long) question.
Just changed the fmx in my ZH out for a top loader. Box is in good nick, new exedy diaphragm clutch and steel flywheel were used, new shifter, drives fine and changes gears fine, except for an intermittent squeal that started a day after the swap. cant really pinpoint where its from, although it does it while driving (clutch out) so cant be pilot bearing. wont do it at all reving in the driveway.
My only thought is that when clutch is out, the diaphragm fingers are rubbing on the throwout bearing, making the noise? is there meant to be a spring from the end of the clutch fork to preload or deload the throwout bearing slightly? If so does it pull the fork off the diaphragm fingers or onto them? and where uder the floor does it hook to?
car needs to be running reliably before the powercruise up here next weekend! any help greatly appreciated, thanks, Nathan
sly376 Offline
#2 Posted : Tuesday, 17 June 2008 1:58:39 AM(UTC)
sly376
Did you put the sandwich plate in? If so make sure it's not slightly touching on the inner part of the flywheel, I had this problem when I put a steel flywheel on mine. also if you're using the big clapper starter motor you need a spacer plate for the top
snappa Offline
#3 Posted : Tuesday, 17 June 2008 5:32:08 AM(UTC)
snappa
How does the ZH perform Nathan with the manual compared to the auto mate?
I just rebuilt my fmx with street/strip internals and 9 1/2 inch street/strip 3000 convertor. Keen to see how she performs
351 ZH
351 ZH
#4 Posted : Tuesday, 17 June 2008 6:03:14 PM(UTC)
Has a sandwich plate in and has the starter spacer. Tried a spring on hte end of the fork, no difference.. Took it for a long drive on hte weekend, only made the noise when it was cold. Will be running the car at the powercruise this weekend, then will
#5 Posted : Monday, 30 June 2008 7:52:00 PM(UTC)
Well i found the cause of the noise... When i put the new seals and gaskets in the box, the output shaft seal was one of them "GT falcon concours correct" pieces with the rubber dust boot on the back of the seal. It was lubed when i put it in, but it wa
