HZute-efi-VS5L Offline
#1 Posted : Sunday, 15 June 2008 11:08:55 PM(UTC)
HZute-efi-VS5L
got a heap of hz'ish electric window motors i want to test. how do i?
i tried the old fuse in both pos and neg. and connecting to battery. tried 5amp fuses and blew straight away. tried 10amp and same thing. maybe not big enough fuse?
dunno/?
jason
www.stickthisdecals.com.au
#2 Posted : Sunday, 15 June 2008 11:20:49 PM(UTC)
HZute-efi-VS5L
ah its ok think i have it sorted. done a search...
both wires going into the motor are positive. it earths through the door. which makes sence. positive to one makes go up. positive to other makes it go down. this is why the switch is spring retu
classic oz wreck Offline
#3 Posted : Monday, 16 June 2008 12:35:55 AM(UTC)
classic oz wreck
yep..thats it for holden anyway,ford and jap are usually different.
www.classicozwreck.com.au
#4 Posted : Monday, 16 June 2008 1:47:56 AM(UTC)
Commodore are also like Jap & Ford - where you need to reverse the 2 wires, and there is no earthing through the body of the motor.
A lot of people aim to achieve nothi
This page was generated in 0.022 seconds.
