HotRodder Offline
#1 Posted : Sunday, 15 June 2008 11:57:28 PM(UTC)
HotRodder
Has anyone ever fitted a 6 volt horn to a 12 volt system before, I recently purchased off ebay a 6 volt 1937 Ford trumpet horn and dog its load.
What would one need to ask for to connect this baby up so it doesn't damage the electrical system.
#2 Posted : Monday, 16 June 2008 12:09:22 AM(UTC)
horns generally pull around 10 amps so somewhere in the region of a 1 ohm 50 watt resistor in series with the horn power wire would be a good starting point. I doubt 12v would damage it but it may change the note.
Otherwise measure the amperage it uses
HotRodder Offline
#3 Posted : Monday, 16 June 2008 12:19:41 AM(UTC)
HotRodder
A resistor thanks Jamie, I was thinking a regulator.
Ill measure the amperage and see what I can purchase tomorrow.
HotRodder Offline
#4 Posted : Monday, 16 June 2008 12:19:41 AM(UTC)
HotRodder
I'll measure the amperage and see what I can purchase tomorrow.
#5 Posted : Monday, 16 June 2008 12:25:30 AM(UTC)
yeah you can use reducers and so on but you dont really need it for a horn. You just need a load that is going to "eat" around 6 volts.
some info on reducers here
ebay item 180217549090
#6 Posted : Monday, 16 June 2008 12:29:36 AM(UTC)
actually from the ballpark I gave 1 ohm is probably a little high because it will drop 10v across it and only leave you about 3. Around 1/2 an ohm or a bit more. Anyway measure the amps and go from there
80737k Offline
#7 Posted : Monday, 16 June 2008 12:53:20 AM(UTC)
80737k
Great topic !!!
I have two huge trumpet horns that i was once told are from 48 chev trucks.
They have gone on every car ive owned over the last 20 years and i have hooked them up various ways but now i hook them up together using a relay for each one an
Fossil fuels are YUMMY !
80737k Offline
#8 Posted : Monday, 16 June 2008 12:53:20 AM(UTC)
80737k
Great topic !!!
They have gone on every car i've owned over the last 20 years and i have hooked them up various ways but now i hook them up together using a relay for each one a
#9 Posted : Monday, 16 June 2008 1:41:04 AM(UTC)
Run 2 x 6V batteries in series instead of a single 12V, and hook the horn up via a relay from the centre point of the 2 x batteries to 0V (frame).
If we all had the same (good) taste, who would b
HotRodder Offline
#10 Posted : Monday, 16 June 2008 5:23:59 AM(UTC)
HotRodder
I'll let you know tomorrow night how I get on at the auto electrics.
HotRodder Offline
#11 Posted : Monday, 16 June 2008 5:23:59 AM(UTC)
HotRodder
Ill let you know tomorrow night how I get on at the auto electrics.
#12 Posted : Monday, 16 June 2008 8:17:08 AM(UTC)
I run a vintage 6v Klaxon off 12 volts, sounds like something in terrible pain, but seeing you usually only operate it for a few seconds I doubt it would be damaged, the structure of these old horns is pretty strong.
#13 Posted : Wednesday, 18 June 2008 3:04:32 AM(UTC)
Wire a headlight bulb in series with the horn that should do the trick but hide the bulb somewhere unless you want an eerie glow in your engine bay every time you hit the horn.
This page was generated in 0.100 seconds.
