meecar Offline
#1 Posted : Monday, 16 June 2008 6:07:08 AM(UTC)
meecar
Hey all i was wondering if anyone knows the best way to take of vk doors.
#2 Posted : Monday, 16 June 2008 6:13:21 AM(UTC)
Get yourself down to your nearest Repco or any other auto shop that sells ABW tools.
Buy a pin puller set. Using that pin puller, remove the bottom pin by pulling it up, and the top pin by pulling down.
You'll also need to tap out the pins holding th
#3 Posted : Monday, 16 June 2008 6:13:21 AM(UTC)
Youll also need to tap out the pins holding the
#4 Posted : Monday, 16 June 2008 6:31:02 AM(UTC)
egads there is a puller??????
i thought you just knock them out?
thanks for the heads up
i remember having a hell of a time with an LC - will puller work on those?
#5 Posted : Monday, 16 June 2008 6:44:46 AM(UTC)
Sorry Jamie, Im not familiar with LC hinges, so I cant say for sure.
Just a tip with commodore ones - spray them daily (or twice daily) with WD40 for a few days running, before you plan to pull them - it makes life heaps, heaps easier.
Mi
#6 Posted : Monday, 16 June 2008 6:44:46 AM(UTC)
Sorry Jamie, I'm not familiar with LC hinges, so I can't say for sure.
80737k Offline
#7 Posted : Monday, 16 June 2008 7:25:30 AM(UTC)
80737k
Buy yourself a door remover/installer, its takes the back pain out of the job.
http://gallery.oldholden...+for+people+005.JPG.html
"Junk is something you throw out three weeks before you need it"
Fossil fuels are YUMMY !
80737k Offline
#8 Posted : Monday, 16 June 2008 7:25:30 AM(UTC)
80737k
Buy yourself a door remover/installer, it's takes the back pain out of the job.
