#1 Posted : Monday, 25 October 2004 10:58:35 PM(UTC)
Looking to get new spark plugs for the 308 in my HZ wagon. It's a blue WB block, quaddy carb, standard points ignition and is dual fuel. I run NGK at the moment are these still the best plug? Should I be running a slightly diferent heat range since it's dual fuel, eg one range hotter or colder??
Thanks in advance.
Peter
