Evil Homer Offline
#1 Posted : Friday, 20 June 2008 3:41:28 AM(UTC)
Evil Homer
hi all
Looking at buying a welder for panel work. is there any difference between MIG, Tig or should i just get a Dillon 2000 (henrob).
any suggestion
thanks
#2 Posted : Friday, 20 June 2008 4:00:45 AM(UTC)
Best bet is an MMAW caddy with a TIG attachment. CIGWELD do a good little unit. I've seen it weld steel cans back together. Costs about $1500 plus Argon bottle.
If we all had the same (good) tast
#3 Posted : Friday, 20 June 2008 4:00:45 AM(UTC)
Best bet is an MMAW caddy with a TIG attachment. CIGWELD do a good little unit. Ive seen it weld steel cans back together. Costs about $1500 plus Argon bottle.
If we all had the same (good) taste
HotRodder Offline
#4 Posted : Monday, 23 June 2008 9:21:21 AM(UTC)
HotRodder
I've seen the Henrob being used and after that demonstration its what I would use should I ever need to do panel work although I do have a Cigweld 165 Transmig mig welder thats capable of welding car panels to 4mm thick steel. I used it to build our stora
HotRodder Offline
#5 Posted : Monday, 23 June 2008 9:21:21 AM(UTC)
HotRodder
Ive seen the Henrob being used and after that demonstration its what I would use should I ever need to do panel work although I do have a Cigweld 165 Transmig mig welder thats capable of welding car panels to 4mm thick steel. I used it to build our storag
