cage000 Offline
#1 Posted : Friday, 20 June 2008 8:59:00 AM(UTC)
cage000
took the car to a auto electrician today. had a new plug fitted to the coolant sensor, and the car still plays up. sent a message to inject a carb and they said either plug on coolant sensor, afm or high fuel pressure. the auto electrician checked the afm and said it was fine.been on other sites where people are having the same problems,afm or fuel problems are the most common replys. afm from holden is 550. better off getting another engine.got a afm from wreckers for 55 and still no luck. anyone? anything?
#2 Posted : Friday, 20 June 2008 6:16:08 PM(UTC)
Hi cage000
What is you exact problem, has this been ascertained yet ? In other words, what are the symptoms ?
VLs were nice when they were new, but now theyre 20+ years old, you can write a book on all the gremlins they have.
I see heaps of VLs
#3 Posted : Friday, 20 June 2008 6:16:08 PM(UTC)
Hi cage000
VLs were nice when they were new, but now they're 20+ years old, you can write a book on all the gremlins they have.
I see heaps of VLs
cage000 Offline
#4 Posted : Saturday, 21 June 2008 4:01:24 AM(UTC)
cage000
the problem is the car dies and sounds like it flooding when u put the foot down. i have put a brand new radiator,hoses,leads,plugs,thermo.thermo housing,coolant temp sensor,had a plug put on yesterday by a auto electricion,petrol treatment,cleaned all co
cage000 Offline
#5 Posted : Saturday, 21 June 2008 4:02:19 AM(UTC)
cage000
also i am from tamworth.nsw
mmazz30 Offline
#6 Posted : Saturday, 21 June 2008 6:52:53 AM(UTC)
mmazz30
Have you checked the return line hose fitting at the tank (swirl pot jet)that i mentioned a few days ago?
Slide the return line off and see if it has the little plastic jet shaped like a "V" fitted on the end of the metal tube.
It would take 5 minutes t
#7 Posted : Saturday, 21 June 2008 6:28:08 PM(UTC)
Hi Guys.
As I mentioned, my preferred method of diagnosis is to measure things.
Fit a fuel pressure gauge just before the fuel rail & take the car for a drive. See what the pressure does while the fault is occurring. This checks out the entire liqui
#8 Posted : Saturday, 21 June 2008 6:28:08 PM(UTC)
Hi Guys.
As I mentioned, my preferred method of diagnosis is to 'measure' things.
