Have just fitted HQ front discs and VC rear discs to my HT.I am using the standard HT V8 power booster.My question is which master cylinder to use. Is the HT type OK or will a later model fit i.e. HX,HZ.
Hi Rick.
Stay with the HT m/cyl, all HK to HZ have the same 1 inch bore size.
The only mod you need to do, is remove the residual pressure valve, because you are now running rear discs.
Dr Terry. |
Rick
Did you change the stud pattern on one end, as HQ and VC are different stud patterns?
Thanks Byron ,Yes I have changed rear stud pattern to HQ, Thanks again. Rick
hi rick whom did you get to change the stud pattern or did you do it your self ? as i am about to do the same change over due to lack of parts for banjo centres indeed for salisburys too cheers
Had the conversion done by a mate as a foreign order.
when i asked who drilled your new stud pattern is he diff specialist or say a boilermaker in other words were does one take his axles to have them re drilled ?
