You have been a member since:: 15/06/2008(UTC) Posts: 168
Does anyone know the widths of the LX & LJ v8 Torana differentials and did either come out with disc brakes as standard units.
LJ didnt come out with V8 LH/LX same bango diff for 6 or 8 except for the A9X which is a salisbury with disks, UC had rear disk brake option with a small salisbury diff like commy
LJ didn't come out with V8 LH/LX same bango diff for 6 or 8 except for the A9X which is a salisbury with disks, UC had rear disk brake option with a small salisbury diff like commy
LX Salisbury with discs Ill check it out for the width.
LX Salisbury with disc's I'll check it out for the width.
Hi LC-LJ 53" O/A LH-LX 56 1/4" Tony
if you have a LX with salisbury check the trailing arms to see if they are straight or have been modded or the floorpan mounting points moved as only A9X had these and to fit it in the floorpan was UC with different locations for top mountings
No I dont have any differential yet as I'm looking for a suitable V8 Holden differential to fit under a Toyota Crown.
No I dont have any differential yet as Im looking for a suitable V8 Holden differential to fit under a Toyota Crown.
We have 55 1/4'' to play with so 1/2''inch on either side aren't too. Does anyone know of a V8 differential with a closer rear track.
We have 55 1/4 to play with so 1/2inch on either side arent too. Does anyone know of a V8 differential with a closer rear track.
