Thanks: 1 times Was thanked: 557 time(s) in 532 post(s)
quote: Originally posted by Adj
I ran 406 sbc in hk gts best both worlds sb weight with bb power if put gd higher compression heads. 400 bores simesed so they can run hot but 4 core took care of that. Always thought 4 inch block with 400 crank was 383 400 block with 350 crank equals 377
4" bore with 400 crank is 377ci. It becomes 383ci when bored +0.030". Most people call them 383 though, as are stroked 308s called 355 when the capacity is 350ci (5.7L) as HSV built them. I do understand the 383 thing as its not a factory capacity, but 355 is blatantly wrong otherwise every 30 thou up 202 should be a 205, or 308 should be 312 or whatever it is. _______________________________________________________ If we all had the same (good) taste, who would buy all the Fords? |
Thanks hk1837 checked my maths was going off 30 thou blocks
is it really possible to create a project like that? chev put into hg monaro? sounds interesting. i think i gonna let to try it. ____________
[url="http://www.carparts.com/Hood-Scoops/600023145.car"] hood scoops[/url] Edited by user Friday, 4 February 2011 2:35:29 AM(UTC)
| Reason: Not specified
Thanks: 5 times Was thanked: 14 time(s) in 12 post(s)
quote: Originally posted by HK1837
... but 355 is blatantly wrong...
Ever tried finding 4.00" pistons or a holden block that will take 4.00" pistons after doing 11ty million miles? most of the engine guys advertise them as 355 because they are taken straight to +0.030 so OTS and readily available chev pistons can be used and most of the kits are supplied with +0.030" for the same reason. so while youre correct, your kinda not as well lol.
11.38@117mph will go quicker 11.34@121mph went quicker and faster, just not quick enough. now being rebuilt with less cam, much less comp, and a turbo.
A mob in Castlemaine makes 2" BBC into HKTG headers that work with standard steering box. I bought a set for a BBC dyno run. Plan to put them into my HK with a centrifugally blown 454 at a later date. There are a couple of low rise BBC manifolds that should keep things under the hood.
