HotRodder Offline
#1 Posted : Monday, 23 June 2008 9:33:48 AM(UTC)
HotRodder
Whats the advantages of using Yella Terra heads
on say a 253 Holden v8 head.
I've seen on ebay kits are available as bolt
on's and the ones where some machinery works required,
which would be the better setup just for a daily streeter.
Edited by user Monday, 23 June 2008 9:35:11 AM(UTC)  | Reason: Not specified
The Yeti Offline
#2 Posted : Monday, 23 June 2008 3:58:36 PM(UTC)
The Yeti
yella terra heads arnt just roller rockers or in some cased didnt come with roller rockers, I have a set of yella terra heads with big valvs and port job but conventional rockers
IMHO theres nothing wrong with conventional rockers on the street the be
Macquarie Towns Hot Rod Clubs new website http://www.hotrodclub.info
See The Yeti's Chev build at
http://www.ozrodders.com...rd/viewtopic.php?t=17919
HotRodder Offline
#3 Posted : Monday, 23 June 2008 11:19:01 PM(UTC)
HotRodder
On the heads I have there is no rocker bits so since I have
get them anyway I was wondering if there is any advantages so
I'll just buy the standard ones then, do you have any idea
where I can get the new standard ones from.
HotRodder Offline
#4 Posted : Monday, 23 June 2008 11:19:01 PM(UTC)
HotRodder
Ill just buy the standard ones then, do you have any idea
#5 Posted : Tuesday, 24 June 2008 3:00:49 AM(UTC)
On a 253 I reckon you are better off with standard heads.
Guest (6)
