BAD WB Offline
#1 Posted : Monday, 23 June 2008 9:27:15 PM(UTC)
BAD WB
Is there a way to work out how much hp is lost through the drive train with out putting it on the dyno, Say if you already have the figures for the engine?
Steve_in_Adelaide Offline
#2 Posted : Tuesday, 24 June 2008 2:35:47 AM(UTC)
Steve_in_Adelaide
About a 20% loss (in general)
Aqua HQ GTS 350 Coupe
White SS Hatchback Torana 355
jabba Offline
#3 Posted : Tuesday, 24 June 2008 7:18:16 PM(UTC)
jabba
There is a drag racing site (which I cant track down) where you factor in acceleration, weight, tyre size, etc and it spits out an "effective" hp reading.
Is called an HP Calculator or something of that nature.
________________________________________
Edited by user Tuesday, 24 June 2008 7:18:53 PM(UTC)  | Reason: Not specified
jabba Offline
#4 Posted : Tuesday, 24 June 2008 7:18:16 PM(UTC)
jabba
There is a drag racing site (which I can't track down) where you factor in acceleration, weight, tyre size, etc and it spits out an "effective" hp reading.
JBM Offline
#5 Posted : Tuesday, 24 June 2008 7:25:56 PM(UTC)
JBM
Bob Kotmel who writes a drag orientated column for Street Machine refers to Moroso HP and ETs derived from engine size, tyres, diff etc.
Couldnt find any reference to it on the Moroso site.
James
Mr.Jones Offline
#6 Posted : Tuesday, 24 June 2008 8:42:35 PM(UTC)
Mr.Jones
Doesnt Moroso HP comes from a chart dependent on ET or MPH. 'Generally' whatever you have at the engine in kW will convert to hp at the rear wheels ie efi 5.0L 165kW at the engine are usually around 120-130kW (160-170hp) at the wheels. Work on auto 30% ma
Edited by user Tuesday, 24 June 2008 8:51:22 PM(UTC)  | Reason: Not specified
Voltaire
Mr.Jones Offline
#7 Posted : Tuesday, 24 June 2008 8:42:35 PM(UTC)
Mr.Jones
Doesnt Moroso HP comes from a chart dependent on ET or MPH. Generally whatever you have at the engine in kW will convert to hp at the rear wheels ie efi 5.0L 165kW at the engine are usually around 120-130kW (160-170hp) at the wheels. Work on auto 30% manu
Voltaire
#8 Posted : Tuesday, 24 June 2008 8:55:07 PM(UTC)
Look for "Moroso power speed calculator"
Its just a slide rule that references weight in lbs versus horsepower and gives a theoretical best case et/mph, Then you use this mph to reference gearing/tyre size for your car with trap rpm.
Itll get you a
#9 Posted : Tuesday, 24 June 2008 9:00:13 PM(UTC)
Also, im yet to find any software that equates to all engine/driveline combos and power at each end.
The dyno is just another tool for measuring improvement, it wont account for all external variables so ignore it. Find a guy you trust to tune it and k
#10 Posted : Tuesday, 24 June 2008 9:00:13 PM(UTC)
Also, im yet to find any software that equates to all engine/driveline combo's and power at each end.
JBM Offline
#11 Posted : Tuesday, 24 June 2008 9:01:16 PM(UTC)
JBM
This what it looks like:
from here:
http://www.moroso.com/ca...isplay.asp?catcode=27042
James
You only h
