kanks Offline
#1 Posted : Tuesday, 24 June 2008 9:13:32 PM(UTC)
kanks
my wifes vx supercharger has developed a bad sqeek under acceleration it seems to b comeing from pully at end of snout has any one had one of these repaird as not 1 mech even gmh dealer has been able to help me thanks
tripple webers Offline
#2 Posted : Wednesday, 25 June 2008 7:16:48 AM(UTC)
tripple webers
Hi you might have better luck if you do a search in L67Torque its an Australian site dedicated to Holdens V6 Supercharged engine
#3 Posted : Wednesday, 25 June 2008 7:16:48 AM(UTC)
tripple webers
Hi you might have better luck if you do a search in L67Torque its an Australian site dedicated to Holden's V6 Supercharged engine
#4 Posted : Monday, 30 June 2008 5:11:43 AM(UTC)
I had the same problem sometimes. When i changed the charger pulley to a smaller one to wind up the boost,,noise was gone, however came back in a few months. Take the belt off, clean all pulleys thouroughly, with kero and a toothbrush if you have too!! Th
kanks Offline
#5 Posted : Monday, 30 June 2008 5:53:29 AM(UTC)
kanks
thanks paul thanks for your response cleaned all pullys and put a new belt on and that seems to have fixed noise cherrs
Paul85 Offline
#6 Posted : Monday, 30 June 2008 6:04:02 AM(UTC)
Paul85
Hope the squeek stays gone, but remember, winter is a bit more common for squeeks. What i also did was inspect the belt, and clean out any crap in the grooves. But it has been a common problem
All the best
V6 S/C, 10PSI boost, 1:9 Rockers, Type S CAI, Twin redback catback, Cooler plugs, Top gun Leads.
Guest (5)
