hey yall, whats a ruff idea on how much power a diff takes to just turn?? small car and large?? also ruffly how much to drive the gearbox? say small gearbox? 4 cylinder? thanks already muchly
ptpro some men see things as they are, and ask "why" I dream of things that never were, and say, "bloody ripper idea mate, lets try it",!! |
more than basketcase than a bear! DOH!!! |
Guess - about 10% each??
hey there byron, i dont understand? I think,, are you meaning 10% of the cars power?? each? eg 80hp car, box uses 8hp and diff 8hp? or 160hp,,box 16hp, diff 16hp? thanks though, i have been on this ev forum, and was trying to figure out how much |
I reckon you would lose more power pushing that van through the air....? always be nice to Darth bear....he could delete you at any time...
surely muskell, eerrhh? was that darth bear?? or daft bear?? shirley you would not wanna delete the bear!! you are right be interesting to see what she handles like? and how heavy she is? but i did need to find out how much hp a gearbox and a diff t |
old mate said his turbo 350 takes 24hp and his trimatic only 7hp
hey thor, i have heard the t350 and t400 take heaps hp, and the 9 inch diff heaps too. i am guessing but every box and diff must take at least 5>10hp just to turn it, and the diffs about the same?? but i am not sure what hp relates to kw? if even a |
The amount of torque required to start a diff turning after o/haul is approx. 12 LB/IN. This is measuring the preload on the bearings, the friction in the gears and the drag on the seal and no other loads. The figure quoted doesnt include axles fitted. A
The amount of torque required to start a diff turning after o/haul is approx. 12 LB/IN. This is measuring the preload on the bearings, the friction in the gears and the drag on the seal and no other loads. The figure quoted doesn't include axles fitted. A
so casper, what is that ruffly in hp or kw? for the less mathematically enclined?? cheers bcb
you tend to lose about 1/3 of your power through the driveline. I had my 148Kw Falcon dyno tuned and they managed to get it's RWKW up to 100. It was a manual so an auto would lose a bit more.
you tend to lose about 1/3 of your power through the driveline. I had my 148Kw Falcon dyno tuned and they managed to get its RWKW up to 100. It was a manual so an auto would lose a bit more.
The formula for the relationship between torque and power is half way down this link: http://en.wikipedia.org/wiki/Horsepower
hey thanks casper for the friendly imfo,, cheers bcb
