shortys4711 Offline
#1 Posted : Tuesday, 1 July 2008 10:15:28 PM(UTC)
shortys4711
Hey all
I have a 96 VS commodore running the ecotec v6 the car has done about 140,000kms. all of a sudden it has started to run really rough as if it was only running on 5 cyclinders, have done a compression check and is all good, also change leads and plugs, have also had our snap on scan tool on it but it is coming back with no faults, no engine light or warning lights are comming up while driving. It doesnt seem to be missing on just one cyclinder
Any help would be great.
Daniel
jabba Offline
#2 Posted : Tuesday, 1 July 2008 10:20:47 PM(UTC)
jabba
The coil packs are noted for occasional failure / breakdown. Try a known good coil pack, and see if the situation improves (rather than buying one and finding it is something different).
Keep the shiny side
shortys4711 Offline
#3 Posted : Wednesday, 2 July 2008 4:55:30 AM(UTC)
shortys4711
Hi Jabba
thanks for the tip mate, but i gave it a go tonight and still no change, so I can cross that off my list of problems,
hq350 Offline
#4 Posted : Wednesday, 2 July 2008 7:33:54 AM(UTC)
hq350
My suggestion would be o2 sensor, try swapping with another vehicle to see if problem is transferred to other vehicle
#5 Posted : Thursday, 3 July 2008 8:03:26 AM(UTC)
Sounds silly but check your sparkplug leads. I had a VS ute which suddenly started running rough. Turned out someone had used VT leads on it, which have a different length and a kink near the cap. One of the leads had shifted slightly and was touching the
shortys4711 Offline
#6 Posted : Wednesday, 23 July 2008 7:34:17 PM(UTC)
shortys4711
The car is still not running right, have now also checked the O2 sensors, cam sensor, crank angle sensor, air flow meter, the car also has new leeds and plugs done, and changed coil pack assemble, the fuel pump and filters where change about 4 months ago,
shortys4711 Offline
#7 Posted : Wednesday, 23 July 2008 7:36:22 PM(UTC)
shortys4711
#8 Posted : Wednesday, 23 July 2008 9:00:03 PM(UTC)
bad fuel?
clean the throttle body up and the hole above, with carby cleaner spray.
SpecialK Offline
#9 Posted : Wednesday, 23 July 2008 10:15:24 PM(UTC)
SpecialK
I used to own a 94 VR exec that had a very similar problem, turned out to be some crap in the fuel filter, give it a good bash or better yet change it and see if that improves the problem. Hope you find what it is mate.
When only cubes will do!
