YetAnotherForum.NET Help
basketcasebear Offline
#1 Posted : Thursday, 3 July 2008 11:14:51 AM(UTC)
basketcasebear
still trying to find out what hp kw, whatever it takes to run a box and diff??
byron said 20% but i need to be more specific! i need to answer a question in another forum,
eg, they measure the output at the rear wheels?
rwkw!! so what would be the kw at the engine??
will the difference tell me what the gbox and diff is taking to turn it?
it has been written in here, but i cant find it? cant remember the figures? or post
i seem to remeber a t400 takes more kw/hp to run than say a 4 speed?
can someone help without too much jargon,
bcb
ptpro
some men see things as they are, and ask "why"
I dream of things that never were, and say, "bloody ripper idea mate, lets try it",!!
DOH!!!
#2 Posted : Thursday, 3 July 2008 7:14:40 PM(UTC)
Ah! I get it now. You want a specific answer to a non-specific question?
#3 Posted : Friday, 4 July 2008 12:48:27 AM(UTC)
Mate there is no specific formula.
Like you said a th400 will sap more power than a 4 speed manual. A 9" diff will sap more than a Borg Warner. Dont forget too that tyres and uni joints will also take (small amounts of) power away as they all have fric
Edited by user Friday, 4 July 2008 12:50:29 AM(UTC)  | Reason: Not specified
#4 Posted : Friday, 4 July 2008 12:48:27 AM(UTC)
Like you said a th400 will sap more power than a 4 speed manual. A 9" diff will sap more than a Borg Warner. Don't forget too that tyres and uni joints will also take (small amounts of) power away as they all have fri
musksell Offline
#5 Posted : Friday, 4 July 2008 4:34:56 AM(UTC)
musksell
Mr Bear its really easy......
...but at the same time quite hard.....
of course you can work out how much power is needed....but..
...go to...or ring up would be better ....latrobe university engineering department......and they will give you some guid
#6 Posted : Friday, 4 July 2008 6:11:02 AM(UTC)
basketcasebear
yes youall,
i am being a bear who asks a question for which there is no real answer?
but who needs uni guru,s when i have you guru,s??
but, i wondered whether if i put a motor mower engine on the shaft of a gearbox and diff, whithout the wheels touchin
Edited by user Friday, 4 July 2008 6:30:37 AM(UTC)  | Reason: Not specified
DOH!!!
#7 Posted : Friday, 4 July 2008 8:55:16 AM(UTC)
Using the calculations supplied in your other thread on this topic,
it would take approx .75hp - 1hp to turn your assembly WITH NO LOAD, e.g, with wheels off the ground.
AND using a manual gearbox.
#8 Posted : Friday, 4 July 2008 9:05:17 AM(UTC)
FastEHHolden Offline
#9 Posted : Friday, 4 July 2008 4:31:31 PM(UTC)
FastEHHolden
The answer ist a fixed percentage...but its not linear either.
If I had a 100 hp 149 engine in an eh with aussie 4 and banjo...then by applying the 30% idea...I have 70 hp at the treads.
But if I flick the 149 and fit a turbo 202 and now have 300
#10 Posted : Friday, 4 July 2008 4:31:31 PM(UTC)
FastEHHolden
The answer is't a fixed percentage...but its not linear either.
#11 Posted : Saturday, 5 July 2008 1:28:13 AM(UTC)
Hi Bear,
Heaps of engineering formula's and tearing out a bit of hair may be needed. But (and I have not tried this)
Maybe you could use the manufacturers spec's for flywheel Hp/Kw verses the spec's from a dyno shop for the the rear wheel Hp/Kw,
The
#12 Posted : Saturday, 5 July 2008 1:28:13 AM(UTC)
Hi Bear,
Heaps of engineering formulas and tearing out a bit of hair may be needed. But (and I have not tried this)
Maybe you could use the manufacturers specs for flywheel Hp/Kw verses the specs from a dyno shop for the the rear wheel Hp/Kw,
The dif
#13 Posted : Saturday, 5 July 2008 4:08:19 AM(UTC)
basketcasebear
thanks all oil37,fast eh,etc,,,[would not have bean fasterer than my yellow gold eh prem wagon? in 1974!!! by the by.]
gives me an idea,
clearly box and diffs although varying depending which ones they are, use a fair amount of hp/kw, just to turn them
DOH!!!
#14 Posted : Sunday, 6 July 2008 6:34:39 PM(UTC)
#15 Posted : Monday, 7 July 2008 3:54:53 AM(UTC)
basketcasebear
yeah casper,
what a waste of money?
$1>2 fill up,, same as petrol!! @20k,s
some of the proffesional elec cars are reasonably good range, and good power.
but these home made numbers are a laugh!
the ev site i am on, they go on with so much jargon,
DOH!!!
Guest (5)
