klompy Offline
#1 Posted : Friday, 4 July 2008 4:24:12 AM(UTC)
klompy
Hi what are the best brand of springs to lower a V8 HQ no more than 2 inches and maybe improve handling,Thanks Mike.
#2 Posted : Friday, 4 July 2008 5:35:34 AM(UTC)
king springs or lovells or pedders what ever suits your budget, check with your RTA for legal requirements or you may get done by the cops and waist your money.
you could go some thicker sway bars and put a HZ swaybar on the rear, some GT monroe gas shoc
trubluhq Offline
#3 Posted : Friday, 4 July 2008 9:15:59 PM(UTC)
trubluhq
My HQs have gone thru Pedders. The spring rates and shock kits work real well. The trick with HQs are all those rubber bushes. If you cant do it yourself it gets costly. The HQ rear is rather fiddly and heavy to work under. The front camber shims should b
trubluhq Offline
#4 Posted : Friday, 4 July 2008 9:15:59 PM(UTC)
trubluhq
My HQ's have gone thru Pedders. The spring rates and shock kits work real well. The trick with HQ's are all those rubber bushes. If you cant do it yourself it gets costly. The HQ rear is rather fiddly and heavy to work under. The front camber shims should
JBM Offline
#5 Posted : Saturday, 5 July 2008 2:23:22 AM(UTC)
JBM
Drop spindles are also an option for the front. It will retain your suspension geometry without increasing bump steer.
James
