#1 Posted : Monday, 7 July 2008 1:05:45 AM(UTC)
gday everyone i'm looking for some swaybar d rubbers to suit the standard mounting brackets with a 24mm swaybar but in rubber and not that poly crap any ideas or links any help would be good i've tried rare spares but they dont seem to make them for some reason as i asked in adelaide branch maybe they may have them in other states thanks
les Offline
#2 Posted : Monday, 7 July 2008 5:59:15 AM(UTC)
les
I assume you are talking HK not GTS if so try part number 7410667
Les
#3 Posted : Monday, 7 July 2008 7:31:40 AM(UTC)
gday les sorry its for my mates 350 ht gts we looked up the part number in the ht parts book & it comes up as part #2806489 were not 100% its a genuine sway bar but ive been told 24mm is the correct size do you have these available
#4 Posted : Monday, 7 July 2008 7:31:40 AM(UTC)
gday les sorry its for my mates 350 ht gts we looked up the part number in the ht parts book & it comes up as part #2806489 were not 100% its a genuine sway bar but i've been told 24mm is the correct size do you have these available
les Offline
#5 Posted : Monday, 7 July 2008 9:30:06 PM(UTC)
les
No sorry we do not make them at the moment
#6 Posted : Tuesday, 8 July 2008 3:17:07 AM(UTC)
any plans to make them as i've been lead to believe that these are for the bathurst models and i'm sure there is a demand for them i'll take 3 sets myself these are the ones with the high spot in the centre of the rubber.
#7 Posted : Tuesday, 8 July 2008 3:17:07 AM(UTC)
any plans to make them as ive been lead to believe that these are for the bathurst models and im sure there is a demand for them ill take 3 sets myself these are the ones with the high spot in the centre of the rubber.
les Offline
#8 Posted : Tuesday, 8 July 2008 5:53:16 PM(UTC)
les
les Offline
#9 Posted : Tuesday, 8 July 2008 5:53:16 PM(UTC)
les
#10 Posted : Tuesday, 8 July 2008 6:45:01 PM(UTC)
Hi les
These rubbers have the same profile from FE to WB, it's only the hole size that varies.
Most people are not happy with urethane bushes in this area, rubber type is much better. Maybe Rares could make these in various sizes. It's not often you
#11 Posted : Tuesday, 8 July 2008 6:45:01 PM(UTC)
Hi les
These rubbers have the same profile from FE to WB, its only the hole size that varies.
Most people are not happy with urethane bushes in this area, rubber type is much better. Maybe Rares could make these in various sizes. Its not often you g
les Offline
#12 Posted : Tuesday, 8 July 2008 8:57:31 PM(UTC)
les
I started looking at the GM drawings we have and found that the drawing for 7410667 also has reference to 2806489 the GTS bush; they are the same except the GTS one has a 22mm hole.We also make 7410667,9932800,9938001 & 9942693.
les Offline
#13 Posted : Tuesday, 8 July 2008 11:18:33 PM(UTC)
les
HK307
try part number 9942693 its fron a HZ it may fit it's 22mm ID
les Offline
#14 Posted : Tuesday, 8 July 2008 11:18:33 PM(UTC)
les
HK307
try part number 9942693 its fron a HZ it may fit its 22mm ID
#15 Posted : Tuesday, 8 July 2008 11:57:40 PM(UTC)
If its rubber you want, and you get the 22mm one, get a piece of 3/8 dowell, cut a slot down it with a hacksaw, feed in a strip of sanndpaper, and wrap it around the dowell.
Put it in a power drill & sand it gently until you get the hole out to about 24m
#16 Posted : Tuesday, 8 July 2008 11:57:40 PM(UTC)
If it's rubber you want, and you get the 22mm one, get a piece of 3/8 dowell, cut a slot down it with a hacksaw, feed in a strip of sanndpaper, and wrap it around the dowell.
#17 Posted : Wednesday, 9 July 2008 3:50:46 AM(UTC)
gday les i do have a sample dont know if its good enough for a copy but the d bush seems to only run in the hk t series maybe earlier models the hg has a different type as the hk t which is held in by a raised section in the centre of the rubber were the
les Offline
#18 Posted : Wednesday, 9 July 2008 5:03:25 AM(UTC)
les
hazzard county Offline
#19 Posted : Friday, 25 July 2008 10:02:15 AM(UTC)
hazzard county
let us know when they are available les i'll take a set of 24mm ones
#20 Posted : Friday, 25 July 2008 10:02:15 AM(UTC)
hazzard county
let us know when they are available les ill take a set of 24mm ones
