cage000 Offline
#1 Posted : Monday, 7 July 2008 8:04:27 AM(UTC)
cage000
finanlly got the problem sorted.checked the fuel system and noticed the internal fuel pump wasnt working. pulled it out and solded one of the wires which was loose, connected a battery charger to it,put it in a bucket with fuel and tested how much fuel it was pumping. 3 to 4 litres in 30 seconds.put it back in and checked it with the external pump and it was spot on. 1 letre in 30 seconds.the only problem the car is having is it wont go into 4th. gets to 190 no problems in 3rd but wont go into overdrive. whats the go?
meecar Offline
#2 Posted : Wednesday, 9 July 2008 7:50:42 AM(UTC)
meecar
is it a 3 speed box with the over drive button or is it a 4 speed auto
cage000 Offline
#3 Posted : Wednesday, 9 July 2008 4:53:30 PM(UTC)
cage000
its a 4 speed auto.has the power butten on the shifter but nothing else.
#4 Posted : Wednesday, 9 July 2008 7:28:43 PM(UTC)
Hi Guys.
The auto in the VL is a 4-speed, but as meecar has suggested the overdrive gear is selected electrically, not by the shift lever.
The power on/off button changes the shift timing & when it's in 'power on' mode it won't go into 4th gear.
#5 Posted : Wednesday, 9 July 2008 7:28:43 PM(UTC)
Hi Guys.
The power on/off button changes the shift timing & when its in power on mode it wont go into 4th gear.
The
cage000 Offline
#6 Posted : Thursday, 10 July 2008 6:04:00 AM(UTC)
cage000
when going from a start the car will go through 1st. holds 2nd for a while, goes into 3 then nothing else. at 100km it sounds like its at high revs but will go to about 180/190. my bro has a turbo 4 speed. his car also doesnt go into 4th but gets up to 22
meecar Offline
#7 Posted : Thursday, 10 July 2008 6:57:26 AM(UTC)
meecar
yeah my vl held 2nd for a bit and also had the needle bouncing of 200 with ease i would probaly sus out your power button
#8 Posted : Thursday, 10 July 2008 7:14:16 AM(UTC)
With the amount of money you guys would have spent on racetrack hire fees to do your 190km/h 'tests' you should have been able to afford 20 new transmissions.
A lot of
#9 Posted : Thursday, 10 July 2008 7:14:16 AM(UTC)
With the amount of money you guys would have spent on racetrack hire fees to do your 190km/h tests you should have been able to afford 20 new transmissions.
A lot of pe
cage000 Offline
#10 Posted : Thursday, 10 July 2008 7:42:16 AM(UTC)
cage000
racetrack hire fees? im talking about driving around town. this is my work car. just want to get it up to scratch to be a reliable car that will get me from a to b. the car didnt cost me anything but i have put some cash in it to make it run better. the c
