Natmeisterus Offline
#1 Posted : Monday, 7 July 2008 6:05:19 PM(UTC)
Natmeisterus
gday,
i recently bought a speco boost/vac gauge, ranging from vac 30-0-30 boost to use to check vacuum on my 253. I used the supplied t piece and fittings, but when connected at idle it sits on 0 and with a quick hit of throttle the needle jumps to maybe 5 then straight back to zero. My engine is only mild, 253 quaddie/kc manifold/elec ign, but i really did expect to see more of a reading. Does this seem right, or can someone please point me in the right direction?
Nathan
jabba Offline
#2 Posted : Tuesday, 8 July 2008 1:10:15 AM(UTC)
jabba
I know exactly what has happened (as I did it myself and fell into the same trap).
You have connected into the venturi vacuum port, which controls the vacuum advance in the distributor.
You need to connect to the manifold vacuum port, which is eithe
#3 Posted : Tuesday, 8 July 2008 5:45:38 AM(UTC)
Natmeisterus
thanks jabba. How much vacuum should i be expecting my gauge to read?
ill swap some hoses around tomorrow and see how i go.
#4 Posted : Tuesday, 8 July 2008 5:45:38 AM(UTC)
Natmeisterus
i'll swap some hoses around tomorrow and see how i go.
jabba Offline
#5 Posted : Tuesday, 8 July 2008 6:29:53 PM(UTC)
jabba
You should expect around 20" at idle. A lumpy cam may only give around 8". Engine braking it should climb to 25 - 30". Cruise should be 15 - 20". (That is what I am seeing on my tired 350.
j
Keep the sh
#6 Posted : Wednesday, 9 July 2008 3:38:35 AM(UTC)
Natmeisterus
thanks again jabba
jabba Offline
#7 Posted : Thursday, 10 July 2008 5:53:36 PM(UTC)
jabba
No probs.
How did you get on?
#8 Posted : Friday, 11 July 2008 11:51:01 PM(UTC)
Natmeisterus
yeah good mate, soon a u tapped into the correct line i could her the pssssssss froma mile away. It sits on about 12-15 on idle. Thanks very much again for your help mate
cheers nathan
jabba Offline
#9 Posted : Saturday, 12 July 2008 12:03:56 AM(UTC)
jabba
A hiss noise doesnt sound good. give it a spray with CRC or WD40. Figure out if there is a vacuum leak and plug it.
12-15 is pretty good for a mild engine.
jabba Offline
#10 Posted : Saturday, 12 July 2008 12:03:56 AM(UTC)
jabba
A hiss noise doesn't sound good. give it a spray with CRC or WD40. Figure out if there is a vacuum leak and plug it.
Guest (6)
