adam PERTH Offline
#1 Posted : Wednesday, 9 July 2008 9:11:48 AM(UTC)
adam PERTH
a mate of mine is restoring a windowless FE panno.
going with HQdisks up front.
What is the best booster to run?
not real keen on external VH40 or VH44, more looking to adapt LH torana one or VC commodore style.
We have a V8 HT / XU1 style one, but it is too big to run with the 308 in there as well.
any suggestions?
HZute-efi-VS5L Offline
#2 Posted : Wednesday, 9 July 2008 9:18:53 AM(UTC)
HZute-efi-VS5L
VT maybe? only issue with a vt setup is maybe the disc rear not drum.... good thing about them though is they are small.....
maybe a dual diafram one from a hz or a wb stato disc rear one. the master will have to be a drum rear one obviously. so ge
www.stickthisdecals.com.au
adam PERTH Offline
#3 Posted : Wednesday, 9 July 2008 9:34:43 AM(UTC)
adam PERTH
Yeah, i May have to look for other makes / models altogether.
the main reason we aren't going with HQ / WB is the diameter is too big, and will hit the rocker cover on the 308.
not much room in der FE!
i think the VC comm may be ok, and commonly drum r
adam PERTH Offline
#4 Posted : Wednesday, 9 July 2008 9:34:43 AM(UTC)
adam PERTH
the main reason we arent going with HQ / WB is the diameter is too big, and will hit the rocker cover on the 308.
i think the VC comm may be ok, and commonly drum re
#5 Posted : Wednesday, 9 July 2008 12:18:02 PM(UTC)
VB-VC drum rear boosters are quite small, single diaphragm units.
The dual diaphragm disc-rear units are much larger (deeper) and will possibly cause similar issues, but the diameter is around the same.
Stick to VB/VC, as in VH they started fitting th
#6 Posted : Wednesday, 9 July 2008 4:24:09 PM(UTC)
I have helped fitting a VC/H unit to an FC, no problems at all. It is running HR disc front, drum rear.
Warren
#7 Posted : Wednesday, 9 July 2008 5:03:01 PM(UTC)
try an XB falcon type, good for all type of conversions
"ALL WE LEAVE IS MEMORIES.."
"ANYONE CAN RESTORE A CAR, BUT IT TAKES BALLS TO CUT ONE...."
adam PERTH Offline
#8 Posted : Thursday, 10 July 2008 4:17:10 AM(UTC)
adam PERTH
cool, i have given him a VC commy one, cheers.
