#1 Posted : Thursday, 10 July 2008 4:06:58 AM(UTC)
hi what is the biggest talepipe you can get for a hj 6 cly? i would like to get one as big as poss around 25 cm cheers
#2 Posted : Thursday, 10 July 2008 4:56:51 AM(UTC)
There wouldn't be enough ground clearance for one that big on a standard car. Jack the back up about 12 inches and then it should fit. Do the same at the front, fit 30 inch wheels, get a step-ladder to get in and out of the car and now you will look too c
#3 Posted : Thursday, 10 July 2008 4:56:51 AM(UTC)
There wouldnt be enough ground clearance for one that big on a standard car. Jack the back up about 12 inches and then it should fit. Do the same at the front, fit 30 inch wheels, get a step-ladder to get in and out of the car and now you will look too co
Pittin Offline
#4 Posted : Thursday, 10 July 2008 7:51:37 AM(UTC)
Pittin
are you talking length or diameter? your a ****er if you mean diameter.
