Can anyone give some info on torries as i know nothing but might know where a couple are.what do i look for on compliace plates to distinguish gtr's, xu1's etc. Thanx |
b.sacconi |
GTR and XU-1 read the same on the ID plates on first glance. Later LJs had other distinguishing marks like XU-1 for the engine and P in the VIN number instead of L (GTR), plus the trim code can also give them away. You are better off getting ID details of |
GTR and XU-1 read the same on the ID plates on first glance. Later LJ's had other distinguishing marks like XU-1 for the engine and P in the VIN number instead of L (GTR), plus the trim code can also give them away. You are better off getting ID details o |
most noticeable is, 2 dr,model number- 82911 or 8D11 on PSN and ID plates (if original), pressed shark gill vents in front guards ater that as Byron said need all the numbers and someone who knows to look for telltale signs
Go to a newsagent and buy the AMC ID Handbook for $9.95. Everything you need to know will be there in regards to an 82911 being and XU-1. If the car doesnt meet the criteria then it is a GTR. Simple really. The GMH Torana website can assist after that if
Go to a newsagent and buy the AMC ID Handbook for $9.95. Everything you need to know will be there in regards to an 82911 being and XU-1. If the car doesn't meet the criteria then it is a GTR. Simple really. The GMH Torana website can assist after that if
This is the Torana forum, http://www.gmh-torana.com youll need to sign up to post. James
You only have to be in front at the end of the race. |
thanks heaps for the help. |
b.sacconi |
Im curious as to how information in a book can make all the experts even more dangerous then they would be at present. Correct me if I am wrong, but information sharing makes everyone the wiser. That is what websites attempt to do. That is what a forum su
I'm curious as to how information in a book can make all the experts even more dangerous then they would be at present. Correct me if I am wrong, but information sharing makes everyone the wiser. That is what websites attempt to do. That is what a forum s
Excellent information 'we wreck 81837s only'. I was just trying to help by agreeing with 'GTR & XU-1 numbers' and yourself about the hard copy facts you should take with you when looking at a particular vehicle. If it lines up with factory facts, then fur
Excellent information we wreck 81837s only. I was just trying to help by agreeing with GTR & XU-1 numbers and yourself about the hard copy facts you should take with you when looking at a particular vehicle. If it lines up with factory facts, then further
