basketcasebear Offline
#1 Posted : Sunday, 20 July 2008 8:10:43 AM(UTC)
basketcasebear
thought i could wire in the new rear B/I/Stop lights!! transit 98
but only succeded in no lights at all.!!
have checked fuses,
but wondering if there is a main fuse, for all the lights, and if so,
1. what would it look like,
2 where is likely to be located,? ie,,fuse box? under dash?
3. could it be a relay type one? or in a bigger squarer box? situated in the fuse box area??
and if not, what are they? relays?
hate electrics?
thanks already
thanks
bcb
ptpro
some men see things as they are, and ask "why"
I dream of things that never were, and say, "bloody ripper idea mate, lets try it",!!
Edited by user Wednesday, 23 July 2008 6:26:01 AM(UTC)  | Reason: Not specified
DOH!!!
faircon Offline
#2 Posted : Thursday, 24 July 2008 11:15:12 PM(UTC)
faircon
when you say wire in new lights do you mean new wires or just new lamps???
transits have fuse's under left hand dash insert and relays in (right i think) side of engine bay under cover.
each circuit has its own fuse ie brake tail fuse indicator fuse
faircon = eb xr8 with a na front end....one day
#3 Posted : Friday, 25 July 2008 6:21:40 AM(UTC)
basketcasebear
hi faircon,
thanks for you reply and effort,
i run new wires for 2 new rear lights on rear of camper?
but bluw somethin, cause i now have no lights at all,,head, indi,,stop,,
there is a whole line of fuses in the drivers side fuse box, that do not lig
DOH!!!
faircon Offline
#4 Posted : Friday, 25 July 2008 6:22:25 PM(UTC)
faircon
308 in a transit......how many diffs have you put in it :)....fusable link either looks like the biggest blade fuse you have ever seen or a bolt in section of metal in a insulated box and will almost certainly be in the engine bay.follow main positive fee
#5 Posted : Saturday, 26 July 2008 4:43:21 AM(UTC)
basketcasebear
hay faircon,
i had a quick squiz today, and the thing i found next to main battery, looks about 38mm thick, 80>100mm long, plastic case. i though it was somethin to do with computer?? which is redundant,
starter runs from key, ignition from separate
DOH!!!
