HQforme Offline
#1 Posted : Thursday, 31 July 2008 8:47:18 AM(UTC)
HQforme
Bloody idle problem, again. Heres the short version.
I set everything, no apparent air leaks, all's well, idling beautifully.
Turn the car off. Come back a few hours later....idle's like ****.
This happens no matter how many times i reset it and get it idling smoothly.
HEEEEEEEEEEEEEEEEEEELP!
One point...came home last night, car's idling ****...as i bumped over a rut in the yard, it suddenly became smooth for a few seconds, then went **** again. But if it's sometihng that moves around causing the problem, how does it happen when the car just sits still?
It's is a red 202, mildy worked, mild cam, standard 2inch stromberg.
"Silly modern cars"
#2 Posted : Thursday, 31 July 2008 9:17:18 AM(UTC)
have no idea??
float in carby, settling,, fuel filter, fuel pump,
loose screw in carby??
i will be interested when you find it??
cheers hope it helps
bcb
JBM Offline
#3 Posted : Thursday, 31 July 2008 9:32:19 AM(UTC)
JBM
What type of fuel filter do you have, is the outlet pointing down? Crap from the tank can settle in outlet while the engines off.
James
HQforme Offline
#4 Posted : Thursday, 31 July 2008 9:51:59 AM(UTC)
HQforme
Both valid ideas.
However, I just stripped and rebuilt the carby today, using a new kit. Filters an extra inline jobby before the factory glass top. Actually...i put that in for fear the tank had debris in it. Ive since pulled and cleaned the tank...an
"Silly modern cars"
HQforme Offline
#5 Posted : Thursday, 31 July 2008 9:51:59 AM(UTC)
HQforme
Both valid ideas.
However, I just stripped and rebuilt the carby today, using a new kit. Filter's an extra inline jobby before the factory glass top. Actually...i put that in for fear the tank had debris in it. I've since pulled and cleaned the tank...
"Silly modern cars"
#6 Posted : Thursday, 31 July 2008 10:05:05 AM(UTC)
hey hq,,
as i mentioned fuel filter because,
fuel filters do get crap in them, and when revving pressure keeps them clear, then when you stop, crap settles, and blocks fuel,,,
i would try this first, might be easy fix?
HQforme Offline
#7 Posted : Thursday, 31 July 2008 10:12:16 AM(UTC)
HQforme
Checked it....*sigh*
But you know, ill yank it, put the line back on and see what happens...you never know!
"Silly modern cars"
HQforme Offline
#8 Posted : Thursday, 31 July 2008 10:12:16 AM(UTC)
HQforme
But you know, i'll yank it, put the line back on and see what happens...you never know!
"Silly modern cars"
#9 Posted : Thursday, 31 July 2008 11:06:53 AM(UTC)
most likely some goo in the idling jets, run some carby cleaner through the float bowl (take the top of and let it soak in for a bit)
also could have water in the fuel line that can be a bugger to identify, run some metho through the line from tank to c
#10 Posted : Thursday, 31 July 2008 11:14:52 AM(UTC)
Was this problem there prior to carby o/haul?
Is it auto?
HQforme Offline
#11 Posted : Friday, 1 August 2008 2:11:40 AM(UTC)
HQforme
Manual. And problem was there before, and after the carby rebuild.
When i say i stripped the carby, i stripped it, cleaned all jets, blew out all passages. But ill soak more cleaner through it incase theres a buildup of something.
"Silly modern cars"
HQforme Offline
#12 Posted : Friday, 1 August 2008 2:11:40 AM(UTC)
HQforme
When i say i stripped the carby, i stripped it, cleaned all jets, blew out all passages. But i'll soak more cleaner through it incase there's a buildup of something.
"Silly modern cars"
trubluhq Offline
#13 Posted : Friday, 1 August 2008 2:53:06 AM(UTC)
trubluhq
Had teh same problem. Fault was caused by bits of rubber from new hose lines blocking float open or closed. Put in genuine HQ metal prefilter to protect the WW. Replace the new fuel line with another new one, and re cleaned carby of all crap seen or unsee
Intoit Offline
#14 Posted : Friday, 1 August 2008 4:12:39 AM(UTC)
Intoit
This may be a long shot, but is the float metal or plastic? Had a quaddy on my old torana years ago and it had a black plastic float which had become porous,dont know what type of float strommys have.Mine was good on full noise but would idle good, idle l
--------------------Go Hard Or Go Home
HQforme Offline
#15 Posted : Friday, 1 August 2008 5:15:54 AM(UTC)
HQforme
More good ideas to try.
Had a discovery today....i THINK this is an emissions carby, not pre emissions. It has a valve in the top of the bowl, anti-percolation valve? And that's meant to be actuated by the tip of the accelerator pump plunger. So, if th
"Silly modern cars"
HQforme Offline
#16 Posted : Friday, 1 August 2008 5:15:54 AM(UTC)
HQforme
Had a discovery today....i THINK this is an emissions carby, not pre emissions. It has a valve in the top of the bowl, anti-percolation valve? And thats meant to be actuated by the tip of the accelerator pump plunger. So, if thi
"Silly modern cars"
#17 Posted : Friday, 1 August 2008 6:36:42 AM(UTC)
Vac advance sticking in the dizzy?
PCV valve doing some weird things?
59-Cadillac CoupeDeville, 49-Triumph SpeedTwin, 74-HQ GTS4 Monaro
#18 Posted : Friday, 1 August 2008 8:54:41 AM(UTC)
^ Good point.
Could also be the mechanical advance sticking in the shaft.
#19 Posted : Friday, 1 August 2008 10:35:05 AM(UTC)
What kind of ignition system are you running on the car a points dissy or a electronic system.
A lot of times what seems to be a carby problem ends up being nothing to do with the carby at all.
But a electrical issue.
On saying this when you did the ca
HQforme Offline
#20 Posted : Saturday, 2 August 2008 2:34:45 AM(UTC)
HQforme
I've had the sticking advance, fixed that. Car's original points style. Everything's new but the dizzy and coil themselves.
Good ideas, thanks.
I'll give the PCV a good check right now.
I didn't soak the carby (my bad), but did blow out all ports
"Silly modern cars"
Guest (5)
