what are the LS1 standard EFI engine and tremac 6 speed like i heard these engine either wear out fast or last for a long time? i have had good and bad feedback. and how do you go about puting this combo into a HX tonner. my bro inlaw is still deciding what engine he wants he knows he wants manual but wants either 5.7 efi or 5 litre efi. any info would be great on fitting this to a tonner. he was thinking the carby fed 355 but has decided on standard for fuel reseason as it a daily driver. |
Havent you learnt anything from that guy that gives sermons at church?...Captain whats his name. |
LS1 or later LS6 or even LS2 are a reasonably hard fitment, but Castle Auto Electrics in Melbourne sell most stuff for it. You are probably better off with an auto too, as the original T56 is a big box.
Have a think about a VR-VT 5.7. These are just a |
Arent Castle electrics in Castlemaine....?
Aren't Castle electrics in Castlemaine....?
Yes I think that is correct. Much closer to Melbourne than here!
Castlemaine is 2 hrs west north west of Melb, They are just down the road from the Rod Shop and musuem.
does the t5 bolt to the ls1?
any box that is turbo pattern will bolt to the LS1. T5s were bolted to injected 5.0L V8s which were all turbo pattern.
In cubes we trust.
thats what i figured just didnt know if there was anything else that needs to be done EFI makes things to bloody complicated |
Bundy EFI 308 or 350 (or 377 or bigger if you like) is a snack in HX. LS1 is only harder for three main reasons: The block was never fitted standard to W series Holden, electronics are a little bit more complicated and more detailed Engineering is requir |
quote: Originally posted by boom
any box that is turbo pattern will bolt to the LS1. T5s were bolted to injected 5.0L V8s whic |
ah yep. T5G they were. people have put them on turbo pattern blocks. do they have a removable bellhousing?
In cubes we trust. Edited by user Tuesday, 5 August 2008 2:43:17 AM(UTC)
| Reason: Not specified
