bundybluedog Offline
#1 Posted : Monday, 4 August 2008 2:47:45 AM(UTC)
bundybluedog
has anyone got a diagram or pictures of a how a HX clutch 6 cyl is set up? i have HX pedals and a HQ m20 box with a rattrap type set up can i just buy a new clutch and bracket for the bell housing? i also have no idea of what it may look like.
#2 Posted : Monday, 4 August 2008 3:26:54 AM(UTC)
yeah mate i woudent go stuffing around with the clutch ect you could brake something and yuor car wont go. best to take it to a mechanic and see what he says?
#3 Posted : Monday, 4 August 2008 3:33:41 AM(UTC)
bundybluedog
gearbox isnt in the car its got an auto its for a mate i can put clutches in just need to see how the linckage is setup as i only have a hq type setup.
#4 Posted : Monday, 4 August 2008 5:32:07 AM(UTC)
bundybluedog
also flywheel toque settings if anyone has them. cheers
#5 Posted : Monday, 4 August 2008 6:26:03 AM(UTC)
Bundybluedog have a look here
http://gallery.oldholden.com/HQ_SS/Tech/Gearboxs/
at the bottom of the page are pictures of what you need.
Flywheel to crank bolts Torque is 45-55 lb ft
Paul.
#6 Posted : Monday, 4 August 2008 6:43:37 AM(UTC)
Bundy, get a HZ clutch pedal (or WB V8 pedal) and cable holder bracket that goes with it and a WB or Commodore bellhousing/fork and WB clutch cable. Heaps easier and neater. You can also use a WB 6cyl pedal but it doesn't sit right in HQ-mid HZ as the WB
#7 Posted : Monday, 4 August 2008 6:43:37 AM(UTC)
Bundy, get a HZ clutch pedal (or WB V8 pedal) and cable holder bracket that goes with it and a WB or Commodore bellhousing/fork and WB clutch cable. Heaps easier and neater. You can also use a WB 6cyl pedal but it doesnt sit right in HQ-mid HZ as the WB 6
