has anyone got a diagram or pictures of a how a HX clutch 6 cyl is set up? i have HX pedals and a HQ m20 box with a rattrap type set up can i just buy a new clutch and bracket for the bell housing? i also have no idea of what it may look like. |
Havent you learnt anything from that guy that gives sermons at church?...Captain whats his name. |
yeah mate i woudent go stuffing around with the clutch ect you could brake something and yuor car wont go. best to take it to a mechanic and see what he says?
gearbox isnt in the car its got an auto its for a mate i can put clutches in just need to see how the linckage is setup as i only have a hq type setup. |
also flywheel toque settings if anyone has them. cheers |
Bundybluedog have a look here http://gallery.oldholden.com/HQ_SS/Tech/Gearboxs/
at the bottom of the page are pictures of what you need. Flywheel to crank bolts Torque is 45-55 lb ft Paul.
Thanks: 1 times Was thanked: 557 time(s) in 532 post(s)
Bundy, get a HZ clutch pedal (or WB V8 pedal) and cable holder bracket that goes with it and a WB or Commodore bellhousing/fork and WB clutch cable. Heaps easier and neater. You can also use a WB 6cyl pedal but it doesn't sit right in HQ-mid HZ as the WB |
Bundy, get a HZ clutch pedal (or WB V8 pedal) and cable holder bracket that goes with it and a WB or Commodore bellhousing/fork and WB clutch cable. Heaps easier and neater. You can also use a WB 6cyl pedal but it doesnt sit right in HQ-mid HZ as the WB 6 |
