GeeR Offline
#1 Posted : Tuesday, 5 August 2008 9:07:31 PM(UTC)
GeeR
Hello,
Ive decided its best I replace the two foot-well pans in my HQ ute - particularly before I go and re-carpet, re-insulate the floor. They arent exactly rotten but seem very thin with a couple of pin holes and the drivers side has a little crack I assume is going to open up at some stage.
Not having had to do this before, are there any issues I should be careful with?
There are a few people selling these - has anyone experience on which might be better, which to avoid?
Finally, any feedback on what the expected cost is to have someone cut out the old and and re-weld the new pans in?
Thanks for reading.
___________________________
WTB:
- HQ-WB(?) bench seat 4-speed shifter
- HQ-WB ute rear window
- HQ-WB standard rims
- HQ-HX coupe front windscreen mouldings
- HQ-HX coupe door mouldings (the stainless one running along top of door exterior)
The Yeti Offline
#2 Posted : Wednesday, 6 August 2008 2:55:22 AM(UTC)
The Yeti
Ive never had people do it for me, but form experance
measure twice cut once is the most important advice.
whats your welding like. if its so so, get some one else to do it, keep in minde its a mono construction car (or as good as) and the floor p
Macquarie Towns Hot Rod Clubs new website http://www.hotrodclub.info
See The Yeti's Chev build at
http://www.ozrodders.com...rd/viewtopic.php?t=17919
GeeR Offline
#3 Posted : Wednesday, 6 August 2008 8:32:13 PM(UTC)
GeeR
Thanks very much for the advice.
Unfortunately Ive not learnt how to weld - being a pretty important area to get right as you said, I will need to find someone to do it for me.
I guess Id better get around and try to compare the quality of the avail
WTB:
GeeR Offline
#4 Posted : Wednesday, 6 August 2008 8:32:13 PM(UTC)
GeeR
Unfortunately I've not learnt how to weld - being a pretty important area to get right as you said, I will need to find someone to do it for me.
I guess I'd better get around and try to compare the quality of the ava
WTB:
