2 Pages<12
#21 Posted : Saturday, 9 August 2008 7:41:18 AM(UTC)
VL engine would be about the same degree of difficulty as the V6. Both would require that you use the donor car's engine, box, fuel tank with pump/s and front cross member.
Both would then require some custom wiring be done and both would require a cu
Edited by user Saturday, 9 August 2008 7:46:57 AM(UTC)  | Reason: Not specified
#22 Posted : Saturday, 9 August 2008 7:41:18 AM(UTC)
VL engine would be about the same degree of difficulty as the V6. Both would require that you use the donor cars engine, box, fuel tank with pump/s and front cross member.
Both would then require some custom wiring be done and both would require a cus
meecar Offline
#23 Posted : Sunday, 10 August 2008 1:24:31 AM(UTC)
meecar
thanks jim5.0 ill put some thought to doing that,id probaly still rather do the motor change as i have customised the inside of my vk and it would be a pain to swap it all to another car.
meecar Offline
#24 Posted : Sunday, 10 August 2008 1:24:31 AM(UTC)
meecar
thanks jim5.0 i'll put some thought to doing that,i'd probaly still rather do the motor change as i have customised the inside of my vk and it would be a pain to swap it all to another car.
#25 Posted : Tuesday, 12 August 2008 12:47:50 AM(UTC)
Another thought. If you don't mind losing the ability to run on petrol you can just fit your existing 3.3 with a good set of headers and an EFI inlet manifold with the injector holes blocked off and the throttle body replaced with a Gas Research mixer
#26 Posted : Tuesday, 12 August 2008 12:47:50 AM(UTC)
Another thought. If you dont mind losing the ability to run on petrol you can just fit your existing 3.3 with a good set of headers and an EFI inlet manifold with the injector holes blocked off and the throttle body replaced with a Gas Research mixer
meecar Offline
#27 Posted : Tuesday, 12 August 2008 1:07:08 AM(UTC)
meecar
thanks for that idea i might have to do some thinking about that, with headers i heard a rumor that standard exhaust manifold acts like headers is this true?
#28 Posted : Tuesday, 12 August 2008 2:17:39 AM(UTC)
The VK EFI's had stainless steel headers as standard fitment. These were as good or better than any aftermarket headers at the time.
If at first you d
#29 Posted : Tuesday, 12 August 2008 2:17:39 AM(UTC)
The VK EFIs had stainless steel headers as standard fitment. These were as good or better than any aftermarket headers at the time.
If at first you do
meecar Offline
#30 Posted : Tuesday, 12 August 2008 2:20:03 AM(UTC)
meecar
thanks mate.ill let yas know which way i go with it.
meecar Offline
#31 Posted : Tuesday, 12 August 2008 2:20:03 AM(UTC)
meecar
thanks mate.i'll let yas know which way i go with it.
Guest (10)
2 Pages<12
