quote: Originally posted by Ayios
V8 HTs have the 2, 6" wheel brackets on the drivers side of the boot.
307 HTs will be rarer than HKs for two reasons. Firstly 307 was the standard engine in HK Brougham, but HT Brougham standard engine was a 308. Secondly standard V8 in HK was a 307, but in HT 307 was only standard if you wanted a V8 auto. If you orderd a V Edited by user Monday, 11 August 2008 10:02:58 PM(UTC)
| Reason: Not specified |
307 HT's will be rarer than HK's for two reasons. Firstly 307 was the standard engine in HK Brougham, but HT Brougham standard engine was a 308. Secondly standard V8 in HK was a 307, but in HT 307 was only standard if you wanted a V8 auto. If you orderd a Edited by user Monday, 11 August 2008 10:02:58 PM(UTC)
Cheers Byron, a lot of info there always good to learn more.
Cheer's Byron, a lot of info there always good to learn more.
i think byron means 437 not 337
You are correct. Thinking with blinkers on again! Will fix post above.
What the other 50% Byron.... The missing fuel tank hump? |
______________________________________ Speed has never killed anyone, suddenly becoming stationary... thats what gets you |
Got it.
Current estimate of HT's fitted with option L30 (307) is 2300. So guessing less than 50% were in GTS's, that'd be say 1100. Better figures may be around one day though.
_______________________________________________________ If we all had the same (go |
Current estimate of HTs fitted with option L30 (307) is 2300. So guessing less than 50% were in GTSs, thatd be say 1100. Better figures may be around one day though.
_______________________________________________________ If we all had the same (good) |
The car has been pulled off ebay.
yeah has been pulled off ebay becuse this the car is not what the owner makes it out to be.....have a look at the mat black engine bay i mean come on if you wanted to mock up a car i thought you would have gone to the trouble of getting the right paint fo
This thread is worth a re read. I still am concerned by minor things like the 5 ltr badges in the wrong spot, no black out on the grille and the other things that have been pointed out, why put in the effort that obviously went into this car and not compl
