justin77 Offline
#1 Posted : Tuesday, 12 August 2008 11:31:56 PM(UTC)
justin77
Whats the difference between Torana LH/LX brake master cylinders with large nut at the front of brake pipe to large nut at the rear of brake pipe?
#2 Posted : Thursday, 14 August 2008 3:57:27 AM(UTC)
What justin is wanting to know is that of the 2 master cylinders he has 1 has a larger nut on the front brake pipe and the other has the larger nut on the rear brakepipe. Is there a difference in the 2 cylinders
dagwoodone Offline
#3 Posted : Thursday, 14 August 2008 4:02:17 AM(UTC)
dagwoodone
proprtion valve internally i believe is it a disc disc or disc drum ?
#4 Posted : Thursday, 14 August 2008 4:10:05 AM(UTC)
He has fitted HQ discs on the front with torana drums on the back which has larger wheel cylinders
#5 Posted : Thursday, 14 August 2008 4:10:05 AM(UTC)
He has fitted HQ disc's on the front with torana drums on the back which has larger wheel cylinders
dagwoodone Offline
#6 Posted : Thursday, 14 August 2008 4:20:58 AM(UTC)
dagwoodone
easy to find out ring Repco and ask for the 2 internal sizes of the wheel cyls
#7 Posted : Thursday, 14 August 2008 4:45:07 AM(UTC)
Hi Guys.
All HK to HZ & LC to UC brake master cylinders have a 1" bore size. Only the A9X & late UC have the late PBR style with an internal proportioing valve (disregard the notes below for this type).
The 2 holes (ports) on the side are different
#8 Posted : Thursday, 14 August 2008 5:04:59 AM(UTC)
local auto shop checked with pbr and they could tell him the difference between the 2 cylinders.Is the residual valve behind the olive where the brake line pipe is fitted
#9 Posted : Thursday, 14 August 2008 5:32:41 AM(UTC)
above should have read they could not tell him
