dagwoodone Offline
#1 Posted : Thursday, 14 August 2008 4:16:32 AM(UTC)
dagwoodone
As the tiltle says can anyone tell me and others how to tell the difference between the 2 boxes or do you have to pull apart to check i would like to think you can identify the 2 by the outside somehow, if so what is there too look for. Ive seen so many on ebay saying genuine m21 and they say i was told it was by a mate or the casting number on the side of the box tells you . I can assure you it doesnt as my books say its a casting number only, Any thoughts on this would be appreciatted as i am looking for one.. chers daza
#2 Posted : Thursday, 14 August 2008 6:19:14 AM(UTC)
as far as i know. not alot... 1 machine line on the imput shaft is M20. 2 lines on the imput shaft is M21 and no lines on the imput shaft is M22. thats a basic idea. if a car is running a M20 box and 3.08 ratio diff. it will be quick off the line and quic
adam PERTH Offline
#3 Posted : Thursday, 14 August 2008 6:26:24 AM(UTC)
adam PERTH
if you use the rule of thumb with refence to the imput shaft.
no groove = M22
single groove = M20
Double groove = M21
you will be right 95% of the time.
Go to Bryons site and print out the aussie 4 sp reference guide,
most guys should quote the
Edited by user Thursday, 14 August 2008 6:28:24 AM(UTC)  | Reason: Not specified
dagwoodone Offline
#4 Posted : Thursday, 14 August 2008 8:17:21 AM(UTC)
dagwoodone
Thanks guys a great help CHEERS
This page was generated in 0.142 seconds.
