#1 Posted : Thursday, 14 August 2008 9:02:48 AM(UTC)
Does the HR disk brake front end go into the FC without too much work? Is it the same track?
I realise the outrigger has to be modified but am not sure if the Hr crossmember bolts up to the FC subframe.
thanks
#2 Posted : Thursday, 14 August 2008 6:14:33 PM(UTC)
Hi john.
Fitting an HD/HR ball joint front end into FE to EH is a very common swap. The 4 main mounts are in the same position & as you said, the outrigger needs to be changed. If you are running a Red motor the mounts have to be moved rearward by abou
#3 Posted : Friday, 15 August 2008 8:56:48 AM(UTC)
Thanks a lot Doc, will be fitting a p76 motor and manual box.
