#1 Posted : Friday, 15 August 2008 8:22:12 PM(UTC)
Hi All,
Just wanted some advice and directions on how to fit new front wheel bearings onto the stub axle for a HZ disc brake. Is it a case of tapping down, or do you have to get them pressed in? I have the outer part of the bearing fitted into the disc, just need to know how to fit the inner part correctly. Thanks
#2 Posted : Friday, 15 August 2008 10:11:46 PM(UTC)
Hi Hzed.
The outer (cup) part of the bearing is the only part that needs any pressing to fit. The inner (cone) part just needs greasing & adjusting properly. Get yourself a workshop manual or ask a mate who knows how to do it.
Tapered wheel bearings
Edited by user Friday, 15 August 2008 10:54:35 PM(UTC)  | Reason: Not specified
#3 Posted : Friday, 15 August 2008 10:11:46 PM(UTC)
Hi Hzed.
The outer (cup) part of the bearing is the only part that needs any 'pressing' to fit. The inner (cone) part just needs greasing & adjusting properly. Get yourself a workshop manual or ask a mate who knows how to do it.
vintageholden Offline
#4 Posted : Saturday, 16 August 2008 3:06:20 AM(UTC)
vintageholden
leave the old inner cup there
just grease the bearing
