Rhys Offline
#1 Posted : Monday, 18 August 2008 5:11:36 AM(UTC)
Rhys
Hi Byron and others,
After removing a full length headlining from a HZ Kingswood van the other day I noticed that not only did it have the teeth at the back, but also extra sheet metal spot welded on down the sides (which standard vans dont have). About 50mm high by 2m long. This obviously allows the lining to finish off neatly on the sides and something for the windlacing to clip onto.
I assume all HJ-HZ Sandmans would have this, so knowing this would make it easier to ID a Sandman if the back end was missing or someone had attempted to copy the teeth. Have photos.
Rhys
#2 Posted : Monday, 18 August 2008 10:16:28 PM(UTC)
i have pulled 3 kingswood vans apart and all had a full hood lining and light switches in the doors. i van that stumped me Rhys was a 1 owner XX7 sandman i seen with no hood lining. it never had one. i stopped just behind the cabin area. it was in poor st
#3 Posted : Monday, 18 August 2008 11:49:55 PM(UTC)
Was thanked: 557 time(s) in 532 post(s)
Full length headlining and door switches are standard on Kingswood vans (ie HX-HZ). I've never noticed the side sheetmetal before.
If we all had the same (good) taste, who would buy all the Fords
#4 Posted : Monday, 18 August 2008 11:49:55 PM(UTC)
Full length headlining and door switches are standard on Kingswood vans (ie HX-HZ). Ive never noticed the side sheetmetal before.
Rhys Offline
#5 Posted : Thursday, 21 August 2008 8:45:25 PM(UTC)
Rhys
Interesting Mikey, it must have been a delete option which I'm sure the tradies would have taken advantage of.
I spoke to a guy who bought a maranello red WB van new in 1982 and fully optioned it, with the intention of making it his own version of a W
Edited by user Thursday, 21 August 2008 11:24:20 PM(UTC)  | Reason: Not specified
Rhys Offline
#6 Posted : Thursday, 21 August 2008 8:45:25 PM(UTC)
Rhys
Interesting Mikey, it must have been a delete option which Im sure the tradies would have taken advantage of.
I spoke to a guy who bought a maranello red WB van new in 1982 and fully optioned it, with the intention of making it his own version of a WB
#7 Posted : Thursday, 21 August 2008 9:24:42 PM(UTC)
Mikey, don't forget that the full elgth headlining was actually 2 x separate headlinings ie a front one and a rear one. The rear one may have just been pulled out.
#8 Posted : Thursday, 21 August 2008 9:24:42 PM(UTC)
Mikey, dont forget that the full elgth headlining was actually 2 x separate headlinings ie a front one and a rear one. The rear one may have just been pulled out.
