#1 Posted : Monday, 1 November 2004 2:48:12 AM(UTC)
My steering wheel is vibrating after heavy breaking..pads not good enough??? Dont Know!
Eny 1 have the same problem? Any suggestion 4 a cheap upgrade?
#2 Posted : Sunday, 7 November 2004 3:11:16 AM(UTC)
Sounds more like a steering or bearing problem, just stirred uyp by the braking.
#3 Posted : Wednesday, 17 November 2004 4:52:44 AM(UTC)
Sounds like you haved warped brake rotors. Try DBA Slotted (Part no DBA040SL I think) or Drilled and Slotted rotors. Bendix Ultimate pads should be used in conjunction with either rotors. I went for the slotted rotors and it fixed the same problem in mx V
#4 Posted : Wednesday, 17 November 2004 4:53:41 AM(UTC)
