#1 Posted : Saturday, 23 August 2008 9:35:25 PM(UTC)
having trouble trying to take out my ingnition barrel, any hints?
#2 Posted : Saturday, 23 August 2008 9:49:32 PM(UTC)
Hi tim.
You need a key that works the lock. Put the key in & turn it to the 'ACC' position. Using a paper clip or a thin nail, insert it in the tiny hole on the barrel & press the spring release. This will enable you to turn the barrel further to the l
#3 Posted : Saturday, 23 August 2008 9:49:32 PM(UTC)
Hi tim.
You need a key that works the lock. Put the key in & turn it to the ACC position. Using a paper clip or a thin nail, insert it in the tiny hole on the barrel & press the spring release. This will enable you to turn the barrel further to the lef
#4 Posted : Saturday, 23 August 2008 10:41:05 PM(UTC)
hey thanks,
i have a go
