#1 Posted : Tuesday, 2 November 2004 12:14:09 AM(UTC)
Hi all i need some info on the bars that are fitted to HQ/WB holden subframes.
I took my HX Kingswood to a mechanic to have holes drilled in my subframe to fit the 2 bars that go from the front crossmember to the subframe just behind the front wheel which i belive are RTS bars.
I get a phone call from the mechanic stating that the bars i had were not the right bars so he got me a pair from a wrecker.What i have just found out is that the bars i had originaly are meant to go from the front crossmember towards the front of the car and have to do with a so called outback pack that was offerd by holden.Now my question is what do they actually bolt upto ??????????Is there someother braket or some other mout that they require to be fitted?Any photos would be of great help.Thanks in advance Christopher gmh1975 AT ozonline.com.au
#2 Posted : Tuesday, 2 November 2004 3:03:57 AM(UTC)
I've sent you a diagram I have. Hope it helps.
Steve.
#3 Posted : Tuesday, 2 November 2004 7:11:12 AM(UTC)
Hi Steve,
I have the same bars, I'd be wrapt if you'd send that diagram to me too (qute at oldholden dot com...no spaces and the obvious changes).
Cheers...Dave
#4 Posted : Tuesday, 2 November 2004 8:27:49 AM(UTC)
HI Steve, I have the same queston.I have a HQ but I bought the strengthening bars off a WB from EBAY and don't know exactly where they go . Could you please email me the same diagram on 7249 at tpgdot com dot au THANKS NEIL
#5 Posted : Tuesday, 2 November 2004 10:42:41 PM(UTC)
Id be interested too.
fuzzy1au at yahoo dot com dot au
Thanks in advance
