Can someone tell me what the trim and paint are? I know L32 is 253 and GV7 is 3.55 but why is there a M20 in a 1 toner or is this a standed thing for 253 1 toners?
Model HJ8WM60
TRIM 1888-64W PAINT 568-15951 ENG L32 TRANS M20 RRAXLE GV7
If I agreed with you we`d both be wrong. |
M20 is the normal gearbox for all HQ-WB with if a 4 speed option is selected (or standard as the case may be eg Sandman, SS etc). It is also the normal 4 speed for most HQ-WB 6cyl, however often a 6cyl 1-tonner will have an M22. I think its diff ratio dep |
M20 is the normal gearbox for all HQ-WB with if a 4 speed option is selected (or standard as the case may be eg Sandman, SS etc). It is also the normal 4 speed for most HQ-WB 6cyl, however often a 6cyl 1-tonner will have an M22. I think it's diff ratio de |
1888 is Cotillion White 64W Gazelle Bench Vinyl
"Planet earth is the asylum to which the rest of the universe sends it's lunatics" Voltaire |
"Planet earth is the asylum to which the rest of the universe sends its lunatics" Voltaire |
Thanks for your help and info. Is there some place online where I can just lookup paint or trim codes ? |
At the moment the decoder at O/H is being updated, but the full table can be found http://codes.oldholden.com/rusty/Leroy "Planet earth is the asylum to which the rest of the universe sends its lunatics" Voltaire Edited by user Thursday, 28 August 2008 11:03:46 PM(UTC)
| Reason: Not specified |
At the moment the decoder at O/H is being updated, but the full table can be found http://codes.oldholden.com/rusty/Leroy "Planet earth is the asylum to which the rest of the universe sends it's lunatics" Voltaire Edited by user Thursday, 28 August 2008 11:03:46 PM(UTC)
Thank you for the link Mr Jones |
