#1 Posted : Wednesday, 27 August 2008 9:50:12 AM(UTC)
Wanted any info on upgrading front drums to later model vent disc's and calipers
#2 Posted : Wednesday, 27 August 2008 10:03:21 PM(UTC)
You can use the stub axle and brake assembly from any Falcon XR right up to XG but the balljoint tapers are bigger on all of these. You can purchase taper adapters from CRS or probably hoppers Stoppers and your away.
If you want a really good job Adria
www.earlyfalcons.com Offline
#3 Posted : Saturday, 30 August 2008 4:29:35 AM(UTC)
As Jim said, you can use XR onwards stub axle and brakes, the best way to go is XF, they are vented and you can pick them up cheap for the complete front end. I have sleeves available to make them fit. Don't worry about what people may say about bump stee
