#1 Posted : Thursday, 28 August 2008 1:55:18 AM(UTC)
I think ive got bad fuel and need to drain the fuel tank how hard is it to take the fuel tank out of an 1993 eb falcon.
thanks
meecar Offline
#2 Posted : Thursday, 28 August 2008 7:46:27 AM(UTC)
meecar
there not to hard i found the hardest bit is putting it back in but if you have use of a hoist then it should be pretty easy.
#3 Posted : Thursday, 28 August 2008 7:59:57 AM(UTC)
no hoist but will a trolly jack do it
thanks for the post
#4 Posted : Thursday, 28 August 2008 8:26:43 PM(UTC)
If you remove the boot carpet you will see a 20cm ish round black plate screwed to the floor. Remove this plate to disconnect the fuel pump and lines then you just undo the straps and drop the tank out.
A trolley jack should do it easily.
Or you
#5 Posted : Thursday, 28 August 2008 9:06:14 PM(UTC)
sweet thanks. Fun times huh
Paul351xb Offline
#6 Posted : Thursday, 28 August 2008 9:55:27 PM(UTC)
Paul351xb
Tell the servo you got the fuel from it was bad. take a sample in to them and keep a sample for yourself. They should be liable for any repairs/damage that happens because of this if it was in fact bad fuel.
#7 Posted : Friday, 29 August 2008 11:58:05 PM(UTC)
They are all going to be in the poop soon then as that E10 sh it absorbs water out of the air better than a sponge.
If at first you don't succeed then
Edited by user Friday, 29 August 2008 11:59:01 PM(UTC)  | Reason: Not specified
#8 Posted : Saturday, 30 August 2008 2:20:28 AM(UTC)
hi my name is kerry
