Holdenon Offline
#1 Posted : Saturday, 30 August 2008 1:46:42 AM(UTC)
Holdenon
Does anyone have any photos for air cleaner set ups for the Impco 425 LPG mixer/carb. The one you get with the kits is pretty basic and there seems to be a lack of after market gearin Aus. Due to the height of the mixer standard Holley air cleaners dont fit without modification.
Any creative ways to make a standard one to fit or alternative solutions would be welcome,
cheers,
Scott
email: mckinnons(at)hotmail(dot)com
#2 Posted : Sunday, 31 August 2008 2:04:20 AM(UTC)
maybe a gas ring could be adapted into the snorkel of a standard air cleaner,run a pod style behind the grille for intake, plumb it up to the gas ring, then the gas ring to the snorkel and remove the existing air cleaner element from inside.
similar idea
The Yeti Offline
#3 Posted : Thursday, 4 September 2008 4:16:12 PM(UTC)
The Yeti
run what ever you want a mate of mine is running twin 425s on his tunnelramed chev with a hillborn scoop Ive seen them with 14" chrome filters you just run a 3" filter eliment they look tuffer this way any way another thing Ive seen fitted a few times is
Macquarie Towns Hot Rod Clubs new website http://www.hotrodclub.info
See The Yeti's Chev build at
http://www.ozrodders.com...rd/viewtopic.php?t=17919
The Yeti Offline
#4 Posted : Thursday, 4 September 2008 4:16:12 PM(UTC)
The Yeti
run what ever you want a mate of mine is running twin 425's on his tunnelramed chev with a hillborn scoop Ive seen them with 14" chrome filters you just run a 3" filter eliment they look tuffer this way any way another thing Ive seen fitted a few times is
The Yeti Offline
#5 Posted : Thursday, 4 September 2008 8:31:21 PM(UTC)
The Yeti
this is the tunnel ram I was refering to
This hasnt got an impco under it but this is the caddy style I was refering to
[IMG]http://memimage.cardomain.com/member_images/6/web/2178000-
Edited by user Thursday, 4 September 2008 8:34:11 PM(UTC)  | Reason: Not specified
FastEHHolden Offline
#6 Posted : Monday, 8 September 2008 7:47:50 AM(UTC)
FastEHHolden
I bought one of those $40 ebay bellmouth style aircleaners...drilled the braket out and shifted it to where I needed it and pop riveted it back in....you dead set wouldn't know..its great...you just have to pop the bonnet for a look if you backfire..somet
#7 Posted : Monday, 8 September 2008 7:47:50 AM(UTC)
FastEHHolden
I bought one of those $40 ebay bellmouth style aircleaners...drilled the braket out and shifted it to where I needed it and pop riveted it back in....you dead set wouldnt know..its great...you just have to pop the bonnet for a look if you backfire..someti
#8 Posted : Sunday, 9 November 2008 12:38:40 AM(UTC)
this one is also a 425 impco
The Yeti Offline
#9 Posted : Saturday, 15 November 2008 4:03:58 PM(UTC)
The Yeti
thats it compact unless you realy look youd never no its LPG, long gone are the days when LPG ment they had to look gastly
See The Yetis Chev build at
Holdenon Offline
#10 Posted : Tuesday, 18 November 2008 7:00:23 AM(UTC)
Holdenon
Thanks guys some great ideas and all look great. Unofrtunately on the HQ with a Rochester baseplate there is limited clearance. The standard Impco one even rubbed and had to cut out some of the bonnet bracing.
Has anyone seen the Holley (ex B&M) Hi Tek
The Yeti Offline
#11 Posted : Wednesday, 19 November 2008 2:15:17 AM(UTC)
The Yeti
well theres no reason it wont fit
#12 Posted : Wednesday, 10 December 2008 6:13:19 AM(UTC)
Clearance on HQ is a problem with the 425 mixer on standard manifold on a 253 or 308, one article I read recently was guy who bought a ( elderbrock / edelbrock ). Which is available in a lower configuration than the factory manifold ( not any of the high
This page was generated in 0.141 seconds.
