el_jay_72 Offline
#1 Posted : Saturday, 30 August 2008 8:33:42 AM(UTC)
el_jay_72
Hi, ok bear with me cos i dont reaaly have any idea what this part is called.
On an Lj four door the rear doors have to pins connecting the door. The pin inserts are bolted to the body with to large screws that you would need to use a impact screwdriver to undo. Most people decide that when wrecking they cant be bothered actually removing the pins or the screws so they just gringd straight through. If anyone has one of these parts, after the right hand side (not sure if there all the same) or knows of where i can get them or even what there called your help would be greatly appreciated.
Also located in perth but postage shouldnt be to much.
VERY URGENT as car goes to paint in the following weeks but the doors arent definately lined up cos i cant find this part.
Jason
Torrie Mad
Torrie Mad
#2 Posted : Sunday, 31 August 2008 2:28:33 AM(UTC)
hi mate there is a wrecker in riverstone nsw called western wreckers he has a couple off 4 door toranas he may be able to help i dont know him very well as he just took over the buisness but give him a go 0296271584 hope this helps champ best off luck
This page was generated in 0.280 seconds.
