Beeza Offline
#1 Posted : Sunday, 31 August 2008 5:07:36 PM(UTC)
Beeza
After getting two flat tyers, two days in a row, I discovered that my wheel had become porus. Can anyone suggest where I can find a set of wheels for my doon? Also, when sourcing second hand wheels, what model car do I search for?? Have been told that I will only be able to get off another VP and they are quite rare!
Cheers :-)
#2 Posted : Sunday, 31 August 2008 7:35:48 PM(UTC)
VP non-IRS can take any VB-VS wheel, as well as a lot of VT-VZ.
VP with IRS is an orphan, and the rear will only accept VP/VQ IRS wheels.
You can fit VR/VS trailing arms & hubs into the rear (replacing the VP items) that will then allow you to run any
crowe Offline
#3 Posted : Monday, 1 September 2008 8:34:05 AM(UTC)
crowe
What about putting a tube in it or use some tyre seal. its not like the tyre is going to explode
#4 Posted : Monday, 1 September 2008 8:20:35 PM(UTC)
When I was an apprentice in a Holden dealer we had the same problem with an Irmshcer <SP?> on a group 3. The fix..pull the tyre off and paint the part of the rim which the tyre hides. No more leak.
